JAJ
Thanks NigeBuy 5 shims by all means + all the other replaceable bits of the converter outlet relief valve, not just the spring.
I would suggest that you start with maybe 3 shims and go up or down from there to achieve the specified pressure. Remember that you have to test the converter outlet pressure with the oil at normal operating temperature, around 80C as a minimum.
I’ll have a look at the parts tomorrow regarding the springs, etc.
I was thinking about getting a full new valve but there is a bit of a wait for one and just checked there is for a valve spool as well (might call and check air freight). I will have a good look at the surfaces today but, I was thinking do new springs and seals and see how it went. I figured it would be a cheap way to test it if it looked ok otherwise, but would you replace the spool as well?
If the surfaces (body or spool) were questionable I thought get a full new valve and start fresh and remove all variables.
I will post a couple pics later
Re testing, I think with the temp gauge reading out, I was testing too cold before and it was only just in spec I think.... but i cant find my sheet from testing it when we did the pump. Ill try and find my numbers but the testing recently seemed like the valve wasn't closing and the pressure was going up and down with the revs.
