Cat skid loader advanced display screen gone black
Texas
I took it home with me (so it's disconnected) I am thinking about opening it up (I don't know why but I think is a loose connection somewhere inside it
Texas
It's been a month ,but here are the updates, I took the board out of the display to have it checked and repaired with no luck, so I ended up getting a new one and everything works just fine now.I have been using it daily. Thank you for the help.
63wagon
Cayucos, CA
Did you have Cat install the display or was it a plug and play deal?
What machine S/N are you looking at.? It might be a different display.
There are some Part Numbers of display that need a software flash, others are plug & play. The installation of one works just fine, the other leads to disappointment.
Also have you tried re-initializing your existing display.? See Post #5 on Page 1 for instructions.
Texas
Luckily mine was plug and play , and that is what the local dealer told me too,but as niege says depends on your SN and the part you get.
VOSKOS
Greece
Here........
I can send you a schematic, just need your machine S/N.
Sorry, could i have one if it isn't too much to ask?
Serial number: CAT0262DVDTB02987
  • 0-02-05-f8b45c583d1ec6be0f8e973d7568e998ab64fbcee310a460b9889d5fa4ea592d_e8b253b565e89fde.jpg
Catnewb
America
Have you measured the voltage arriving into the back of the Advanced Display.?
I'lll send you an electrical schematic. You might find it helpful.
Would you happen to have schematic for CAT0299DKFD200527, I tried disconnecting the battery and resetting with with the two outermost buttons, the parking and seat indicators on top will slowly illuminate very dull after 20 seconds and flash a little bit until you release them then back to off. Hoping to find relay, fuse, or wire issue!
Jrod25
Texas
It's been a month ,but here are the updates, I took the board out of the display to have it checked and repaired with no luck, so I ended up getting a new one and everything works just fine now.I have been using it daily. Thank you for the hello you
I know it's been a while, but do you recall how you took it apart? Mine is on A 272D and no obvious ways to take apart short of taking a heat gun to it.
I was told it's bad, so taking apart will not lead me any worse off. Currently took to a shop to give me an actual pass/fail of the panel before I fork out $1,200. It's a low cost compared to $1,200, and hopefully at least I will know for sure.
