Crawlers I photo'd recently.
The guy that put in our cistern had a much newer Hopto on a tandem truck but I think it was a specialty truck like a crane carrier truck rather than a standard tandem truck. He kept it in great shape and pulled his 1 ton flat deck behind it. I looked on the net but couldn't find a similar pic. of it. It was a fairly large excavator. It was very similar to the 300 pictured above but bigger. Maybe a 350 or whatever the next size up was. I'd guess it was late 60's or early 70's.
dayexco
south dakota
i "think", they came out with the 360 and the 550. i think the 550 would have been too big to truck mount. my dad's 300 did not have 360 rotation. i think it was like about 300 if i remember correctly.
It looked to be about 3/4yd size but that was back about 1979/80. If a 300 could go on a single axle I'm sure it was bigger. I can't remember it having outriggers but maybe it did. Pretty sure it had 360 rotation. Did some more looking and maybe it was 500. I found info they were 17 ton crawlers but could be truck mounted.
I've seen that loader before. I wonder if it would be hard on the axle's and driveline having a mix of tracks and tires? On a std. loader different size tires can cause damage. With the tracks on the front there could be a big difference in traction too.
Tones
Ubique
I could see better flotation in soft conditions but big loaders don't work in soft conditions.
Until this jigger came along. Could have been job specific
Hank R
Princeton B.C. Canada
Retired Truck driver and School bus driver
Here in BC the big pit Loaders run chains on the tires so i if there is wheel slippage tires do not get cut and wreck tires. Our mine on the new 944 has chains on all 4 corners then after a year of so they put the rears on the front. which gives a lot longer tire life.
Tones
Ubique
I reckon it's a early version of Logering VTS track system prior to rubber tracks. Bombardier which became ASV used this system
Willie B
Mount Tabor VT
Electrician
I'm inexperienced, and I live where soil isn't hard. Typically a loader is diging into virgin earth in a gravel pit, sand pit. I've never understood the need for heavy track loaders. It seemed a rubber tired articulated loader was enough. Other places, Spud Monkey comes to mind, need tracks to dig.
With old photos unless it is corporate with original captions--I don't put much trust in
open comments directly related to photo. A dated corp press release or dated article
in some magazine from that time period is fairly trust worthy. This last week I saw a
reproduction of a 1939 J series Sterling, It was built from parts and pieces of a military
version using a Peterbilt nose originally and the cab wasn't a Sterling either built during
WWII. The reconstruction was a true J series but the base of it wasn't, many parts
hand made. I made a comment about the fact the military version wasn't considered
a J. A group expert came back with a serial number that had a J-C in it saying yes it
was a J series. Problem is The True J Series only had one J in serial number. So what
happens is what's not so correct becomes correct if repeated enough times, and all
is blurred. There are no real J series left in existence, only a made up one.
J Series below.Plus red reconstructed one.350779594_1049248869383879_1402709558037434714_n.jpg 355697457_653997456771835_2367288522254929568_n.jpg
Willie B
Mount Tabor VT
Electrician
J Series below.Plus red reconstructed one.View attachment 355752 View attachment 355751
That is one elaborate grill.
