BradleySherrell
I’m having issues with my D4d dozer, not sure on the year model I’m thinking late 60s early 70s. Serial is 83j839, 1st gear fwd, and rev always work good. Second gear forward and reverse it will pull its self when cold but will not push dirt. And barely loads the engine. When transmission warms up it won’t even pull itself in second gear fwd or reverse and doesn’t load the engine at all. 3rd gear forward and reverse works cold and hot will pull it’s self but doesn’t have much power either way. Won’t spin tracks to steer in 2nd or 3rd. I’m new to this dozer as my grandpa had it and it sat for 10 plus years. Only gears it will spin tracks in is first gear. And after you work it 4-5 hours the trans temp gets on the line between red and green. Appreciate any help or pointers I can get
