Its P1 pressure...
The units discussion lead us nowhere ... english / metric... whatever it could even be russian system.
But i'll find it intersting CAT publishes in metric system first. Kpa / Mpa / BAR its related.
When they talk about the "load piston plug removed" mean i have to open the rear and remove it from the valve body? Just remove it?
OR is something else. Pls explain... is not making sense to me.
On a more serious note...
Thank you for being clearer about the pressure port you measured at. I am not familar with working on D5H dozers at all and looking at the parts diagrams for the transmission lines, it is set up very different to my D6H. Working from the test procedure that Nige uploaded so we can understand where you are up to and what you are checking is vital.
I for one, will be no help if I cant follow the test procedure with you.... not that I probably have as much to offer as some of the others any way.
Referring to the spec chart, that pressure you measured at full throttle is low. The pressure you measured at low idle, was that in gear or neutral?
If it was in gear... it is very low.
This could point to leakage somewhere internally or a worn out pump. More data/info needed!!!
You will need to measure all the pressures listed in the spec chart or as many as you can for a start. This should point to the cause and tell us what is going on. It could be something simple and easy to fix but we need all the data/info you can give us to work it out.
RE: The "load plug". I don't know, it confused me when I tested my dozer so I just tested the machine as it was. Hoping the more experienced guys can shed some light on it and I can learn something as well??
Some simple stuff, but just want to check.....
1: Have you have checked the trans oil level with it at operating temp while running (assume this is is correct procedure for this machine???) ?
2: Have you checked the breather for the transmission?
3: Someone already suggested... but have you checked the suction line to the trans pump for damage or leaks?
My thinking is sucking air or cavitation. Both will kill pumps very quickly. All these things are easy to do if you haven't done them already. I assumed they had been checked but thought it worth asking.
