kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,172
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
Is it just the camera angle in the first picture or is that disc warped up a bit in the center? I would say if there are any burs in the splines that would cause the discs to hang up a little it would be a good idea to smooth them off. Someone else with more experience with these clutches might know the wear limits on them, but just looking at the pictures they don't look bad but I sure get the spec's and measure each and every one.
Update:
Checked SIS and found this:
4. Check the discs and disc assemblies for wear. If the parts are worn, use new parts for replacement. The thickness of a new set of steering clutch discs and disc assemblies is 2.012 in. (50.10 mm) to 2.222 in. (56.44 mm). The minimum thickness for a used steering clutch unit is 1.800 in. (45.7 mm). mm).
So they don't give wear limits for individual plates and disks but give the total "stack height" which is just as good or better. But I would use a straight edge to check each one for warping as this could trow off the measurement of the stack.
Update:
