willie59
Ok, I've been a wrench for years, but A/C is something I know little about and have only been working into it for the last few years, never had any formal training with it, just a bit of education from others. I have a couple of troubleshooting questions that I hope someone with experience can help me with.
First machine, actually several this has happened to. The system would work flawless at start up. High and low side pressures are good, within the proper ranges. System has a full charge of R134A, no bubbles in sight glass. Evaporator not clogged externally, blowing hard stream of air, air is good and cold. But after running for 10 - 15 minutes, low side goes into a dead vacuum, high side stays up.
It was my theory that system had moisture in it and the moisture froze in the expansion valve effectively blocking it. Perform a recovery of the system, fit a new filter/drier, and do a two hour evacuation. Re-charge system, all things now work proper. My question; in this case, was diagnosis correct, was moisture in the system the likely culprit?
The latest one I'm working on is a Bobcat 442 excavator. Full charge of R134A, no bubbles in sight glass, compressor remains on, not cycling. High and low side pressure is in normal ranges, low around 30 - 40, high around 250 - 275, doesn't really fluctuate. Air blows good through evaporator. But it's not blowing good cold air, just cool at best.
I plan on doing a recovery on the system and fit a new filter/drier, but should I remove the expansion valve and check it out? This one I'm really not sure what to do with.
