Always wanted a engine stand like the ones I used years ago. Today I ran on some
luck, the local JD dealer has been cleaning out any tool that don't have manufacture
tag with rating. This stand was built by a guy I knew in the shop about 40 years ago.
Bolted to the floor using old drill press stand. But all I want is the gear drive, off a
JD model 95 combine final wheel drive. When Buck built it he geared it down a little
more and put a lock for rotation. I have all the steel to build a moveable stand that
will be capable of holding 6,000 plus lbs of engine. Build it after surgery this Nov.
To buy one built like OTC-$8,000, I should get this one done for less than $600.
The yellow pan is just for size reference bottom of 5gal bucket.
