Goodwin93
I have a gs1930 at work that’s giving us some trouble. It will not lift more than 2 or 3 feet with weight on platform while using the platform controls. It will lift from ground controls. I’ve already swapped control boxes, no luck. Pressure tested the system and got about 3200psi at the lift relief. Tried plugging the control box directly into the connection that is at the base, bypassing the harness that leads up the scissor thinking there might be an issue in that stretch. No luck there either. Machine has 4 new batteries, new hydro. filter and fluid is full.
Thinking somewhere between the plug for the control box harness at the base and the motor is the issue... maybe? Any ideas what to look for, or maybe where to look?
