DaleKramer
I own and service my own 2006 S60 Genie Perkins powered Lift SN:6006-13542 which is suddenly generating error codes 51-17 for Drive stick and 61-17 for Steer stick.
As a result, my Steer/Drive joystick is now INOP.
I have the appropriate service manual and schematics.
I am well versed in hydraulics and electronics.
The Boom Up/Down+TurtableRotate joystick operates as normal.
I have the same voltages on the wire harness wires to each of the 'INOP drive/steer joystick' and the 'operating UP/Down+TurntableRotate joystick'.
With both joysticks connected to their harnesses, I get properly changing voltages from all 8 directions in the 2 joysticks (2.4v with centered sticks and movement ranges from 0v to 4.8v when sticks are moved).
I attached the Up/Down+TurtableRotate joystick harness connector to the INOP drive/steer joystick and the INOP joystick will operate the up/down and the turntable so I don't think we have a voltage or joystick failure.
Performing a Joystick Calibration procedure on the INOP drive/steer joystick does nothing (no beeps etc) and the error codes flash continually while calibration is attempted.
I removed the ALC-500 pcb and cleaned this had no affect on the issue.
Any ideas for further isolation of the problem?
I just hope I do not have to replace a $1500 ALC-500 pcb (part# 235411 with software S0816202)
Thanks,
Dale
Thanks,
Dale
