Hunt44km
I have a 2003 Genie S-85 boom lift. Serial # S8003-3563 I have owned it for about 10 yrs with minimal problems. Over time the basket rotate only works when it wants to and the jib the same thing. Then I started to have problems rotating the turn table with boom extended. Some times it will move but very slow!!! The unit runs and drives ok but the turn table only works with the main boom retracted. Added fluid because it has minor leaks. Checked connections, nothing obvious. After looking at it myself with little knowledge of how everything works I contacted the local dealer and they ran a few tests and said that the low pressure pump was bad and needed to be replaced. Because it was winter they wanted to haul it back to the shop to work on it. When they came to pick it up the axles didn't want to retract but after a lot of playing around got them in and loaded. When they went to off load it the steering wouldn't stay lined up and had a hard time unloading it. They worked on it for a couple of hrs on diagnostics and said the machine was junk and I should look at replacing it as the cost would be cheaper $40k. The fluid that was added to the hydraulic system was Dextron trans fluid as that appeared to be what was in the machine. They had contacted Genie and were told that the seals were now all bad and this was the cause of the problem. Because I paid less than 15k for the unit and didn't have 40k to replace I had it towed back and started working on it myself.
I have drained all the hydraulic fluid and replaced with new Rando HD MV. Replaced filters by pump low and high pressure and return filter. I had a bad battery connection at the post and fixed other grounding connections. I was able to extend the axles with no problem and the drive/steering seem to be working as they should. I bought a pressure test gauge and all the test ports read between 2500-3000 psi. I have disconnected the electric safety switch off the boom that shows that it is extended but it functions the same either way. I think my problem has to do with hydraulics but don't know where to start.
Any help is great!
Any help is great!
