Chantrelle
this is my first post in here. Please let me know if the post is not clear and concise enough….
Ive owned a hitachi zx75 ur for about 5 years now. My first machine. I live on an isolated island without a machine mechanic so am having to figure out how to do maintenance and repairs best I can.
The thumb on the machine was put on by the guy I bought it from. So after market. For the last hundred hours or so the thumb opens at normal speed but closes super slow and won’t stay fully closed when gravity is pulling it down or if it’s got a log or rock between bucket and thumb. So when I lift a log up if I don’t keep my foot on the thumb pedal it will start to open and fumble or drop the log.
The thumb hydraulic lines comes from an oil directional control unit mounted on the side of the boom which I can control in he cab and activate the thumb or the swing boom.
The swing boom is controlled by a ram which has begun to have some movement/ play when I turn the machine from side to side. This movement/play in the swing boom gets pretty bad. If I switch the oil between thumb and swing boom the movement goes away for a bit.
So the movement int the swing boom and the slow thumb may have the same source.
When I follow the hydraulic line from the direction control unit i end up near the valve bank at a small metal box.I’m not sure what the box is but I think it’s may be some kind of pressure relief valve. A Hydraulic line comes in one end of the box and out the other. Then splits at a T and goes to both the hydraulic tank and what looks like unit the valve bank.
I have had the thumb cylinder seals replace and the unit inspected. I’ve also had the directional control unit inspected. It has been sugggested that there may be an issue with a pressure relief valve needing to be adjusted.
So all that being said. It seems possible the little box that may be a pressure relief valve may need to be adjusted or replaced. I’ve never dealt with anything to do with the valves or pressure in the machine so have no idea what pressure I’m looking for or if it that would even be my problem. I have purchased an online manual but find it far from helpful.
This feels like a very long winded post but I figure the more information the better likely good that someone may be able to make sense of what going on.
Any advice is appreciated
Thanks.
here’s a picture of the direction control unit. I don’t have a pic of what I think is a relief valve.
Thanks.
