How do I get this wheel off ?
Joe H
Utah
Old storage trailer, probably 10 years without moving but it's got to take a 1000 mile trip so needs some tires.
Got the LR outer off and inner says no way.
Gave it a drink of secret sauce and quit for the day.
Joe H
Nothing wrong with stud pilot. left hand thread, if stuck on hub use a tire bar through hand
holds against drum to loosen or leave thimble nuts loose and remove jack and roll trailer
forward and back to loosen.
Joe H
Utah
I need a square socket to take those studs out ? If they're as tight as the nuts were I can see where that end just twists off.
Socket available where, and what's it called ? Guess call the tire shop in the morning might be my best option as this point. Rolling the trailer isn't going to happen, I have no way to move it. Brakes are an unknown too, although plenty of lining I can see.
Maybe the elves will come tonight and sort it out for me. Maybe not, can't depend on them, only the gremlins show up.
Joe H
Mike_27
Montana
Joe H
It has been a while since I've used it, but i think this is the socket I have;
Tones
Ubique
I have seen a socket that cam in the tool boxes, nut socket one end and a square in the other and holes for a cheater bar. spose they are like rocking horse shyt now.
eastroad
SW Vermont
13/16” square socket should be readily available on Amazon or ebay. Tire guy should have one on his truck if you hire the job out.
I like the idea of popping the tire off and mounting a new one without removing the rim from the truck, but I have never tried that on an inside dual. Done it a few times on a front wheel. If you can get the wheel off, that would be seem to be easiest way to do the job.
Plus changing a tire while wheel mounted on axle--depends on side wall and casing.
The other is getting it seated even on the rim, rim should be off laying down on air up.
cfherrman
Hays, Kansas
I had a guy change a front tire and he mounted it then seated the bead. I just did the same on one of my front tires with a can of ether. I really liked it and it can't go anywhere.
Been years since I even saw a Budd wheel, but after doing some looking I see several different sizes so guess it would be important to measure the square of that "nut". Also would I be right to recall that the "nut" is stamped "R" or "L" to let you know which way to turn them.
