Jamiedavis
Hi
I have purchased a used JCB 214 and used it for first few months with no real trouble.
Lately I have been having trouble with the hoe.
It has the switch and button by the dash. To activate the hoe you toggle switch down and push button. Hoe engages.
Well lately the hoe will just stop working. But here is the kicker. After a period of time passes the hoe will start working again. You press the button and all of the sudden if works.
We have replaced the toggle switch thinking that could be the issue.
All oil levels and hydraulic fluid is good.
Not sure if there would be a sensor for temperature or pressure that could be causing this?
Any help is appreciated
