beauganas
South Carolina
Hey guys,
I'm back again. I got the loader moving (thanks to you guys)...but now she won't stop.
John Deere 444D
Serial DW444DB509098
TM-1341 is the repair manual
PC2059 is the parts catalog
Loader brakes, which previously worked before new hydraulic pump, new brake pump, etc. do not work now at all.
I undid the right brake bleed screw on the front differential today to bleed the brakes and no oil. I basically have the screw hanging in by a thread, wife on the brakes...no oil.
1. Trans oil is about 3/4 of the way on the dip stick between low/high at low idle.
2. A new brake accumulator was installed as part of the repairs I did while the new pump was being made. Brand new, from Deere ($3k walking out the door, painfully ridiculous).
3. I had a new brake filter installed as well while servicing the machine.
4. I believe I have some brake pads left to slow it down (see attached photos)
5. I have changed the oil in both front and rear differentials (I don't THINK that affects brakes, but in case it does).
What diagnostics should I be thinking about? Any other information needed?
Appreciate the help,
BSG
mg2361
Pennsylvania
Equipment Mechanic
Need to check both the brake system pressure and the unloading valve pressure. Is your TM1341 the repair manual or the operation and test manual? The TM1341OP will have all the diagnostics in it. The TM1341RE is tear down and assembly only.
Diesel Dave
Ontario Canada
Hey guys,
John Deere 444D
BSG
What was found in the brake filter housing ?
Was the end of the brake filter cone blown out ?
That brake hydraulic system does not like any kind of debris at all.
Like mg2361 said you need to check the brake system pressure and the unloading valve pressure.
beauganas
South Carolina
Hi Diesel Dave,
I can't confirm; the JD Mechanic replaced it while I was tinkering on something else. He made no specific mention of debris, etc.
No, brake filter cone was intact.
I'm studying up to do these tests; I'll report back my findings...it may be a few days as I need to get a pressure transducer delivered.
Thanks for the help,
BSG
beauganas
South Carolina
Hi mg2361,
Both the 'Loader Operation and Tests' and 'Loader Repair' manuals are given the TM-1341 numbering (at least my versions I bought online do).
mg2361
Pennsylvania
Equipment Mechanic
Then go into the Powertrain section of the Operation and Test manual, subsection Tests, and in there look for the Unloading Valve Pressure Test. Both the unloading valve and brake pressure procedures are in there.
