5EFarms
I bought a 450C a few months ago and not to knowledgeable about dozer issues.
I get a loud grinding/noise when I put it in gear (especially reverse) and release clutch (have a video with sound). OK, so here is the progression:
- I had noticed a slight grind the day before at end of day. Fluid was very low so I added fluid the next morning. Dozing along fine, reversed and when put in forward wouldn't move. Engine would pull down slightly in low, more in reverse and high but no track movement of any kind.. The range shift sticks and is hard to change from 1 to 2, 3 or 4. H-L-R shifts fine as always done in short time I owned it. But I have just used 1st for my purposes.
= Checked linkages and all seems ok.
= Fluid level fine and clean
I did not run a pressure check.
- Went out today, and messed around with range into 2 or 3 gear and it moved forward and I stopped. Then had trouble getting it to go again. Finally got it going again, and heard it with a little grind. Put it under some strain on a brush pile and all of a sudden it started making noise from under seat area. Put in reverse and it made a god awful noise like popping. Put in forward again and made bad noise, Then stopped.
Any ideas guys? I don't even know where to start. I am hoping it is something easier than pulling tranny. Plus I am out in field. Sigh. Thanks much for any input. I certainly don't need a $10K paperweight in my pasture.
