jlgskytrack 5028 , please help .Need to find a way to reroute fork tilt lines. original desing is so bad.
brkmke
buffalo,ny
please help 5028 skytrack telehandler forktilt hydraulic lines running thru boom constantly geting ripped up in guide track or on piston. i know im not the only one. has anyone been succesful with making your desing,modification for underneath outside boom?pully or sspring? anything ?
tractormech
florida
Is the track worn and floppy with sharp edges? Plastic or metal track? And is it supposed to be a Siamese hose in the boom.or two single lines? Check hose length also. Too long can cause issues.
tractormech
florida
Okay. All the pivot points may be worn in the track and it's allowing it to twist sideways and get into the cylinfer and get damaged. Are all the bolts in the track?How about the hoses? Are they supposed to br the plastic siamese hose or what? If they've been replaced with single lines they can get tangled up and twisted around each other and then problems start.
brkmke
buffalo,ny
yes they were replaced with single lines and i also just dicovered at least 2 ends from previuos problems wedged under cylinder!
the diagram only says hose assembly.
