I have a john deere 450D with 13200 hours. Iv been fighting issues with 1239-1 code. I have changed filters / overflow valves checked all screens all lines presure at injection pump at idle is around 37 or so hard to tell because it jumps around so much ! And I don't know if that's normal ? It seems to jump 15 or even 20 psi the needle is almost blurry.? But it seams to be hit and miss on how long it runs well befor it throws 1239-1 code and iv noticed the pump control valve the second one when the fault is present I can unplug the conector with no engine tone change if I Leve the second one plugged in and unplug the fist it will slow the engine down to a pretty low idel about 450 rpm. Plug the #1 back in jumps right back to 750 rmp. I started testing wires back but I don't know how much resistance the ground wire to pcv sould have. ? I pretty consistently get 33.9k ohms to a frame ground on both ground wires 68 k ohms across the 2. Iv switched pcv to see if the issue followed the pcv and it didn't it stayed at the second one. I'm being to bash my head against this thing. With all the work iv done so far the excavator runs way better than when I received it ! It would consistently blow white smoke and sputter no power but after cleaning all lines and screens and new overflow valves all 3 it runs alot better I can get fuel consumption rate of 70 +gallons an hour on the monitor for a little while before it starts loosing power and faults out. I checked the fuel presure limiter. but I believe the system was already running on one pcv and possibly couldn't open it ?. Iv tried a few other things but If anyone relate and have some advice il much appreciate it ! And if any questions feel free to ask
