Ncjetskier
OOPS, my screw up - I think he was questioning how many splines on the shaft. I took my phone and jammed it into the pump area and took pictures. I did find a stamp (not a plate) with what appears to be K3v112 with some letters underneath.
The problem I am running into - is that people that travel and work on equipment - show up, tell me what they think and leave. I realize this is a project machine - but I am willing to pay to have it fixed. It just seems like nobody has the time - and they may not. It is making me learn ALOT about the machine which is a good thing. I just don't know much about hydraulics or servo valves. I did go to U tube University to learn how the pump works so I do understand how the pistons ride on a plate that can be adjusted to increase the pressure. I will go back to U tube University and see if I can learn how to adjust the plate to increase or decrease the pressure.
On Saturday, I pulled the screen filter in the hydraulic tank after draining the fluid. The screen was a mess (probably never cleaned) and my hydraulic fluid was the color of coffee with cream added to it (moisture from sitting too long?) I cleaned the filter and replaced all the hydraulic fluid with new fluid. The screen did have metal shavings but they were steel as they stuck to a magnet but no brass shavings from the pump. The cleaned filter and new fluid did not make a difference.
Is there a high pressure test port to test the pump pressure? I did purchase a pressure gauge that goes up to 5000 psi. The last technician disconnected one of the wires going to a pressure valve (bottom left hand side of the pump) and it did not make a difference. He stated that my problem was not electrical - but he did not do any testing accept for removing the wire from the valve to see if it would make a difference.
I guess my next step would be to test the high pressure side of the pump with a gauge and learn how to adjust the pump plate.
