kobelco sk200lc
bill kelleher
philadelphia
hi, new to the site. I am working on a kobelco sk200lc. The engine cranks fine at first, pump pressure build's up and deadhead's slows engine cranking before it can start acts like dead batteries let it sit for a few hrs and will crank till pressure builds again. I removed both hoses to spool valve and made extensions, drain fluid back to tank from pump engine started and ran is there a system relief or a bypass if so where? or is it something else? any help would be appreciated.
Kobelco ireland
Ireland
Mechanic
Serial number?
Full model (- 6or-6e)?
Year?
Any faults on monitor. If not you need to fit pressure gauges on pumps to see which pump or are both pumps building to much pressure
Kobelco ireland
Ireland
Mechanic
OK some pictures of inside of cab and pumps will help identify it. Also a bit of history about it would help. Did this problem happen all of a suddenly were there any other repairs done just prior to this problem. Any faults on the monitor
LACHAU
Saigon, Vietnam
ser # YQU4178 as for the mod # no other plates on unit this thing is beat up. its a old unit
Hi,
YQU.... is SK200LC/MC Mark IV in the US market (The letter U means US's market).
