You a bad man .This is going 65 pages +.............bet the farm guys!
I've never seen any thing but a screen on a shovel hyd. tank if you have not actually pulled that to look at it do so.The item in the bottom of the tank is supposed to be a brass strainer. It is on the suction side of the pump and there should never be a filter there. Did you watch the video? It shows removing that from the tank.
Have you pulled yours out yet? how about a picture?At the 7:00 point he pulls a strainer out of that filler side. Mine has a paper filter cartridge there. I wonder why the former owner did that? He'd been running the machine like that all the time he'd owned it, as he admitted never touching the hydraulic system during his ownership period.
Now if Komatsu would find the time to respond to my inquiry so I can order these elements.
Remaining concern is why the left travel lever lacks fine control. It goes from zero to full instantly--no fine control--which makes moving and turning the machine a jerky affair. It wasn't like that a week ago.
That's exactly what mine looks like. It doesn't look like a 'screen' but this paper pleated filter. I guess I do have the correct part in there. But the box and part number will make my search a LOT easier. Thanks for posting that photo.
But honey it was a really good deal. You need to keep repeating this till she A. gets tired of beating you or B. shows pity and tells you where she's going on vacation.Geeze, I finally get the hydraulics squared away, and start using the machine and this happens.
How much do these cost to replace?
View attachment 241261 View attachment 241262
http://www.amtequipmentparts.com/rubber-tracks/komatsu/pc60-7/komatsu-pc60-7-rubber-track-assembly-pair-450-x-83-5-x-72/?_vsrefdom=adwords&utm_source=bing&utm_medium=cpc&utm_campaign=**LP Shop - Rubber Tracks&utm_term=4579191053718611&utm_content=10592 | Komatsu PC60-7 Rubber Track - Pair 450x83.5x72 | $3620.99
$6,000 dollars????!!
