Yes.By "keeper plate", do you mean the L shaped bracket that's there to stop the bleeder from coming off if the nut is over loosened?
First crack the large nut (bleeder) a turn to relieve the grease pressure. When the grease stops coming out there should be no pressure left in the track tensioner. You will find that the outer and inner nuts are all one assembly. A groove has been machined into it. This is where the keeper plate fits to prevent the bleeder being unscrewed more than the specified one turn while under pressure. Once you have released the grease pressure the valve assembly can be safely removed but obviously you need to be careful. If there is a location on the front end of the track frame where you can get some wood blocks or wedges in behind the idler wheel so much the better. That will prevent the idler from retracting and avoid nasty surprises.It looks like the outer nut is the one the manual refers to, and is to be loosened no more than one turn, to relieve the grease from the cylinder. The L bracket and both nuts come off to remove the whole assembly for inspection? Can't the Zerk itself be removed without taking it all apart first? Or is that a safety issue?
Here's the deal. It appears as though the grease zerk is a modification. Usually the whole bleeder assembly is one piece and the zerk is part of that, not separate. The clue is that the zerk is normally straight (like the one on the other side), not 90-degree. John C mentioned that in his opinion the assembly has been modified by drilling and tapping a thread for a replacement zerk. I bet if you clean the other side you'll find that the zerk is part of the larger assembly and not a separate item.
So the deal is that deeper inside the bleeder assembly is a ball-type check valve designed to prevent the grease pressure being held by only the little ball in the head of the zerk. The thought is that ball inside is stuck/seized and that's why you can't get grease into it. To get at the check valve you're going to need the whole bleeder assembly removed from the machine.
