Hello currently working on a komatsu WA500. Has error code on the dash for dpf
Reasearched error code which was CA3115 which is doc inlet temp sensor out of range. Was wondering if someone could pint point me here. Check continuity and found that high and low in let sensor on the doc not with in range of what spec should be. But not even sure if I was in the right spot, or if testing properly.
