I have a Kubota v1505 in a mini ex that I’ve been working on. It began blowing smoke out the breather tube then after idling for 30 minutes it started to blow heavy smoke and loose all power, then had zero compression. I replaced the piston rings, head gaskets and glow plugs. I can’t for the life of me get it to fire off, even off a shot of ether. I bled the fuel system, I know kubotas can be a pain but this is the worst. It was hard starting prior to the total loss of compression. Cylinder walls and pistons looked good when I did the rings. I also checked the electric fuel shut off on the pump and it’s working. Any thoughts to get it to run?
