Kubota no start after new piston rings and head gasket
MrFritsch
Wisconsin
When I would crank it over it was like I didn’t have any injectors in. Spun that quick and easily
MrFritsch
Wisconsin
I got impatient and pulled it apart knowing it needed it anyhow. These are the pics of the cylinder walls. I can’t feel anything with my finger nail, looks shiny and glazed for sure with some marks. Picking up a home tomorrow morning before work. Do you recommend a ball or stone hone?
Stone hone--Looks like cylinders were emery papered, part of the carbon soot line above
top ring is still there in some places.
Some photos of piston skirts.
Cliffy
If you dont have a micrometer, take the rings off the piston and put top ring in cylinder. Then use piston to push ring down evenly. Use feeler guages to measure ring gap at multiple locations. This will give you an rough indication of wear in cylinders.
How long have you owned the machine?
I think someone has already been in there recently and its all bad.
Vetech63
Oklahoma
View attachment 320695View attachment 320696
YIKES! Looks like #3 has a vertical gauld
MrFritsch
Wisconsin
All 4 cyclindars have vertical darker marks. I’ll check them with the ring and feeler gauges tomorrow! I bought the machine 2 weeks ago, started doing maintenance and paint on it, then the motor went out. The guy before me said they did a head gasket
Cliffy
Sorry to hear that.
My guess. They overheated the engine. Pulled head and noticed cylinders had picked up. Honed bores, put oversized rings in. Filled with 50w engine oil and sold it to you.
MrFritsch
Wisconsin
He warned me it was hard starting and I noticed the blow by so that makes sense. Hopefully honing the cylinders fixed my issue
56wrench
alberta
A hard starting diesel engine quite often indicates low compression, especially on one with an unknown history. As said, you’re in for a rebuild. A decent cylinder will have no visible vertical scratches, let alone all of them. That many scratches can be caused by carbon buildup on the pistons. Are you sure you didn’t have tight valve lash before you tore it apart? As Truck Shop said, show us some pictures of the pistons- tops and especially the sides(skirts and ring grooves)
Ok-----this is where issues come from trying to answer OP questions no matter the thread. Had all
of info been dumped out at first this would have taken about 4 replies to answer.
Strip it, have it machined, cleaned, engine rebuild 101.
ozarkag
ozarks
That Kubota has press in sleeves that have to be finish honed. Thats why it's almost impossible to throw new rings in and it actually work.
Actually no sleeves at all. parent bore block. You can bore to .5mm oversize, unless that is done already, or if that doesnt get it perfect, or if no oversize pistons are available. Then you will need to bore out and install repair sleeves back to std.
Either way will need finish hone
MrFritsch
Wisconsin
Got them all honed, I used a feeler gauge on the piston ring in the cylinder like you guys suggested and it was well within specs. Got it back together and after a tremendous amount of bleeding fuel she fired up! The compression tester I ordered got pushed back so I didn’t get a number but she’s running again. Thanks for the suggestions everyone.
John V
North Carolina
What did you end up honing them with?
