Everyone missed the obvious :beatsme
Can you say OVERLOADED!!! :duh
Dirt Dogg
While this may not seem right to you poor folks in the Eastern half of our great country, it is perfectly normal here in CA. The lowboy is only 2 axle, but it has 8 tires per axle, and when expanded to 10' wide, the rear trailer group is good for 60,000#. That lowboy is a wide neck Cozad, and looks like a 60 tonner.
Here in CA, we can permit up to 22,000# on the front axle, 46,750# on the drivers of the tractor, and 60,000# on the trailer for a total gross of 128,750# if it is balanced out right. The truck nd trailer will light weight at around 38,000#, allowing for up to 90,750# of load. The D-8R as pictured with the sweeps and extra wide cab probably goes about 85 to 88,000#, so well within legal limits.
I have a similar truck with a 44 ton Murray lowboy and haul D-8R and D-8T with it on a regular basis.
