Need help with Komatsu Bucket and implement information
theuguruofnothing
Idaho
I just bought a 2012 KOMATSU PC308USLC-3. I need to get a rock pick that will fit and I have used my (probably horrible) Google-Fu to try and find a quality one. I do not have delivery on the machine yet... that won't happen for a week or so, so I can't physically measure the pin spacing and diameter that is on it. I can't even find any helpful information from Komatsu or a bucket manufacturer as it seems that the PC308 is a unicorn or too old for anyone to care? Dunno. Does anyone have the magic decoder ring for Komatsu? I have found a single tooth ripper made by Emaq for a PC400 that has dimensions for pins and stuff but can find ZERO links to a like ripper that says anything about a PC308. Will this interchange, maybe?
My machine has a hydraulic quick connect unit on it for the bucket/implement changes and I have no idea if it was a factory Komatsu unit or not.... so probably unhelpful. The ad for the machine is still up so maybe something that someone with a keen eye could use to assist. https://www.proxyequipment.com/listings/1989987-used-2012-komatsu-pc308uslc-3
coalrulz
Western US
Attached has dimensions for a PC308USLC-3E0. Serial number would help determine if it a -3 or -3E0.
  • PC308USLC-3E0.pdf
theuguruofnothing
Idaho
That alone tells me a lot. Thank you very much for that. I will take a look at the sales contract when I get back to it tomorrow and post the serial number. If I am reading this correctly, the pin diameter for the bucket pins is 80mm and the spread is 442mm (or 446mm depending on which page you look at) so that means about 17.4 inches. The PC400 is actually 100mm pin diameter and 21 inch spread so the ripper I was looking at would not fit - too large. I will look further then.
Might you by chance know what the USLC stands for? And the EO as well. Trying to learn as much about this thing as I can.
coalrulz
Western US
US=Ultra Short - designation given to reduced tail swing machines
LC= Long Undercarriage - most Komatsu excavators available in North America are of the longer undercarriage variety. Usually one extra track roller vs the non-LC.
coalrulz
Western US
By serial number you have a -3, 30001 and up show to be -3E0's.
Attached are pin up dimensions for the -3's.
  • PC308USLC-3 Pin Up Dimensions.pdf
theuguruofnothing
Idaho
That is awesome! Thank you for the PDF's. It appears that the numbers are the same for bucket pin diameter and spread are the same between -3 and -3EO models. You have been a great help. Thank you so much.
