plowking740
Thanks to 9420 pullpan for posting a picture of the new "G" series grader. in the "official Conexpo 2008 thread"
Im not sure if this is the model will have the new controls mentioned in other posts, but you can see that they have made some changes to the frame for sure. the front is no longer sloped, but is straight like a Cat grader, hopefully allowing higher blade lift. I also noticed the back end is a little longer and the Ripper/scarifier is set back a little more from the back end of the grader, and it dosent look like the grill extends below the line of the ripper. (which is a good thing. I have pulled mud into the grill before using the scarifer)
it still looks like the exaust pipe still will blow into your face while fueling your machine though. ( I know, I know, it should be shut off to refuel
