New Holland 7610
frodomocho1
USA
I have a 2000 New Holland 7610. When close to full throttle roughly 1700-2200 rpm it starts blowing air into the fuel tank through the fuel return line from the injectors. It doesn't do it at lower RPM's but only at the high end of the RPM range. The fuel from the return line looks fine until it hits the higher RPM then air bubbles appear. It has electric fuel pump that I've replace twice, had injectors rebuilt, new filters and I can't figure out where the air at high RPM's is coming from and nobody else knows either. It pressurizes the fuel tank and the caps (replaced 4 new ones) can't keep up with venting and spits fuel out of them. Anybody have a suggestion?
Mr. Wrench
Ohio
Mechanic
Can you post some pictures of the fuel system, especially the fuel injection pump?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Depending on what inj pump u have, there’s a booster on the top cover that activates from the turbo.. it has a rubber diaphragm that blows out and instead of the pump getting more fuel, the turbo boost goes into the fuel tank..
It sounds as if u didn’t go far enough down the line in ur diagnosis..
The inj pump is A DELPHI..
Mr. Wrench
Ohio
Mechanic
That was exactly where I was headed.
