frodomocho1
I have a 2000 New Holland 7610. When close to full throttle roughly 1700-2200 rpm it starts blowing air into the fuel tank through the fuel return line from the injectors. It doesn't do it at lower RPM's but only at the high end of the RPM range. The fuel from the return line looks fine until it hits the higher RPM then air bubbles appear. It has electric fuel pump that I've replace twice, had injectors rebuilt, new filters and I can't figure out where the air at high RPM's is coming from and nobody else knows either. It pressurizes the fuel tank and the caps (replaced 4 new ones) can't keep up with venting and spits fuel out of them. Anybody have a suggestion?
