Self Loading Logging Truck Photos
SPMiller
Langley, BC
Operator
taken today
carterton
a nz self loading logging truck in action can someone please t ell what sort of truck model it is cheers
[video=youtube;7Au-UOPZYLc]http://www.youtube.com/watch?v=7Au-UOPZYLc[/video]
skadill
B.C. Canada
Kenworth C500 Self loader
A beautiful C500 KW with a Barko 130 shiny new.W.R. Addison truck.shared photo that must be well over 20 years old.
SPMiller
Langley, BC
Operator
It's getting retired soon, could be already. Dorman's timber has been using it in and around Harrison/Chehalis.
skadill
B.C. Canada
United States
Engineer
Here in the Lake States (WI and UP/ Northern LP of MI particularly) for whatever reason self loading trucks have been the rule for as long as I have been alive. There are some loaderless trucks (almost always semi trailer type), but they are in the minority. Typically the only loaders on a job are either on a slasher or a forwarder, neither of which is well-suited for loading trucks, or has the time to do it. The majority of wood is cut into 8' (100" actually) lengths. The most common setup is straight truck + pup, though semi trailers with mid-mounted loaders can be found as well. I'm having trouble attaching pics, but the following links show some typical Michigan setups- because of MI's weight laws, set back front axles and 11 axles on the truck/trailer combo is the norm as it allows ~164k gvw if I recall correctly.
http://usavehiclehub.com/trucks/image_gd/imagegd_big_inside.php?77577575.jpg
https://encrypted-tbn2.google.com/i...GXuXjMxfivJQNQnBehgxjZpkpBJFps9PIijVj_k_OcH4A
Redwood Climber
Blue Lake
Welcome Under_Pressure
Welcome to the Forum Sir! After 5 or so posts, log out then back in and you should be able to post pictures. I am looking forward to what you can teach us about your neck of the woods. Thanks!
hoglogg
malahat bc
wow what a great vid mr skadill i like that loader with the neat little cab,,, what a load of shrapnel also .. hard to make a neat load out of that crap eh ...
skadill
B.C. Canada
