Takeuchi TL130-Problems-Wont Move
A2Z
Florida
I unplugged the relay under the cluster everything seems to be working right i havent been able to drive it or try the funtions because its on a trailer bindered down anyone know what that relay controls?
A2Z
Florida
Yes the link expired hope it isnt the control box, i pull the meter fuse everything works fine but gauge box is dead machine works fine
A2Z
Florida
All my functions work but its stuck in high gear the buzzers on and all the lights are on if i unplug the high speed relay it is in low range. Ive tapped on all the relays it all stays the same i wish i knew what tge relays all did the descriptions are vague. Its like its stuck in first start check mode
skata
midwest
sounds like it could be something to do with the key? or follow the circuits from there.
yohe41
apollo pa
operating engineer/ owner
Ok everyone, I'm having same prob tl130 wont move, replaced proximity switch and both big and small relays still nothing, any suggestions PLEASE
skata
midwest
If you search older posts on here, there is mention of a bypass plug located near the battery. This allows the machine to run but without safety gear active.
skata
midwest
On my tl140 it sometimes won't move. I just tap on the relay cover in front of feet with a hammer and then it works. Lol
yohe41
apollo pa
We have been doing that too, lol but hasn't been working as well lately
heymccall
Western Pennsylvania
If tapping the relay panel helps, then, the relay boards need soldered. Only the triple relays come apart. If you see a Phillip's screw up they the bottom, it doesn't come apart.
yohe41
apollo pa
Ok new issues if I run the machine with the heat on full blast for about 30 mins machine functions normally any ideas
