tool_king
Where you located in NJHi , I have three machines :
TB125
TL130
TL250
I would love any manuals that are available. Thank you
[email protected]
TB125
TL130
TL250
[email protected]
I have a question on this new here .I have been working on a tl130 that will not start. And it has some clicking sounds under where your feet are. Is that where the relay box is .i have a video on what is happening. Thank you .Also, my Takeuchis all have had cold solder joints on several of the relays.
In this panel, the relays, WITHOUT a Phillip's screw in the bottom, can be popped apart, and the cold joints repaired. The ones in question are actually three relays in one, and have multiple connections in the same housing. Pretty sure it's K & L. The ones with a screw thru the bottom have never been an issue.
Even replacement relays have the same malady, so, I stopped buying them. Just resolder the cracked joints within them, and it'll never happen again.
Intermittent shutdown or pilot disable are the most common symptoms.View attachment 196377
Yes, there are relays just in front of your feet behind a cover. What is your email? I can send you the picture of what each do.I have a question on this new here .I have been working on a tl130 that will not start. And it has some clicking sounds under where your feet are. Is that where the relay box is .i have a video on what is happening. Thank you .
[email protected] thank youYes, there are relays just in front of your feet behind a cover. What is your email? I can send you the picture of what each do.
One the way to you .Brand new here but having some of the same problems I have been reading about for 8 pages lol. I have a TL130 s/n 21303593. I know this is an old thread but if any one has the service and electrical manuals and anything else they could email me it would be greatly appreciated. Thanks in advance.
[email protected]
