Takeuchi TL130 Wireing Diagram
tool_king
new jersey
road mechanic owner
Hi guys
Tl130, won't shut off, installed a new shut off solenoid but still not shutting off. Any idea what should be checked to identify the problem? If anyone has an electrical schematic for this machine I'd much appreciate if you guys send one. Thank you
What is your email ?
joshua37
Cullman
What is your email so I can send you one ?
Hey I have a tl130 whose cab has been cut off of it and the wires behind the seat that include the magnetic safety feature to engage the machine when lap bar is down. There are the black and white wire that comes from the magnetic safety feature. There are white wires twisted together with a wire nut and green wires twisted together with a wire nut… there is a red wire, green wire with white stripes, and green wire with some other color then a blue wire wirh red stripes I believe all that I am not sure what to connect to what… I have attached a picture of the wires I need help connecting… please help asap!!
Unfortunately, with the wire nuts, some dubba thought he was doing house wiring. That means unlike machines, they thought green was ground, not black, which they probably concluded that was hot.
Good luck.
tool_king
new jersey
road mechanic owner
joshua37
Cullman
Ok so I ran a wire straight from the battery to the wires I was talking. About… it cranks and will move now for about 10 seconds and then it disengages ages and will not move… at all.. what could be this issue? I checked all the fluids so idk
Simon C
Heavy Equipment Mechanic
All those merreted connections need to be repaired according to schematic, then troubleshooting can begin. Your picture in Post #126 shows a sloppy cut job. Some sparks may have damaged the other wires below. Anyone who did a job like that was not much of a skilled tradesman so dont be surprised if there are more areas to repair. I would start with the schematic if you have it now and go from there.
Simon C
Unfortunately, without a schematic, with color codes, you will have to be tracing wires out. Being that they are cab wires, they control the whole machine.
where is the fuse panel located?
Are we just dealing with the lap bar safety, maybe a seat safety, what about the hydraulic lock out solenoid?
heymccall
Western Pennsylvania
This is from TL150, but should be same.
Room lamp, lever lock proximity switch, wiper, and work lamps are all on same harness up by lap bar switch (lever lock proximity switch)
Screenshot_20250522_212419_Adobe Acrobat.jpgScreenshot_20250522_212456_Adobe Acrobat.jpg
  • TL150 Electrical.pdf
joshua37
Cullman
I don’t have a schematic… where do I get one? Does anyone have one they can email me? [email protected]
The fuse panel is at the base of the left hand controller kinda back right of your right leg when operating…
I don’t know what the lock out solenoid is … I am not sure what all we are dealing with I just know it’s not engaging or if it does it shuts down completely after about 5 seconds
joshua37
Cullman
[email protected]
homeforce
Hi - Newbie here - I have a 2005 MTL16 (same as the TL130) - hard starting, but was turning over with no track movement or bucket lifting - bypassed safety switch, tightened hoses, replaced some fuses, topped off fluid - now won't start at all. Having a hard time troubleshooting - not sure how to understand code on instrument panel or find relay switch part numbers to replace those and see if that's the issue. I believe I have the most recent service manual, but if there are manuals available that could be sent, I'd be much appreciative - [email protected] - Thanks in advance!
