Here's how an old tradesman told me many years back. It works.
Use the right size tip for the job. Make sure its perfectly clean and not been butchered.
Set the Acetylene at 10 psi and Oxy no higher than necessary for the thickness of steel.
Light the torch and with Acet only turn up the flame till it leaves the tip. Back it off just enough till the flame comes back to the tip.
Turn on the oxy enough to lose the carburising feather with the lever down.
You should get a long straight "tube" through the flame and a good flame will crackle when you hit the lever.
That all depends on how good the tip is. Any damage to the central jet or any slag in there,it won't work.
It will cut clean and be a pleasure to use.
