I suppose If your only doing a transmission R&R every once in a great while some of the jacks mentioned above are ok.
I have used just about every style of large transmission jack that's been made at least once. And for most of those one time was enough.
I had a 13spd go haywire some years back on a old Hein Werner. It was safety chained-but still went sideways. Kicked the jack up into the
frame and wedged itself on the other frame rail. Only thing you can do is reach under from a safe spot and hit the oxygen blow the chain
in two and let it hit the floor.
I do too many transmissions not have a real good one. The one below is low profile with high reach and the beast table for Eaton gear boxes.
The only jack I will use. My 2 cents.
