Grader4me
My only peeve was the diff lock switch . In my current application I use it lots , and found it both backward ( compared to Cats ) and just not as good of a switch as it needs to be .
I know with the diff lock switch that was on the Champion that I run, after you hit the switch, you had sometimes wiggle the ass end a bit for it to engage.
When shifting from reverse to forward you need to get in the habit of checking what gear it selects for you and if you don't check the display you find yourself stalling out . Sometimes it selects 1st or 2nd gear , sometimes fifth ! Again , in time , these little annoying things usually work themselves out .
I think that if you are in lets say 4th gear when you stop, shift to reverse then when you shift to forward again it will start out in 4th gear. Same as reverse. It's puts you back into the same gear you used last. If it is set up the same way as the Champions.
Oh , one really annoying thing that I found was it had a control tower creep . Every 15-20 minutes I had to pull back the controls/steering wheel as they slowly seemed to creep further away from me . . I couldn't believe how bothersome this became
Now that is bothersome!
This worked well until I tilted back the blade and that said rock that had somehow lodged onto that sideshift cylinder got caught under the blade tilt cylinder ( whew ... are ya still with me ? Lol ) and it snapped the ram !!!! YIKES
Been there done that! Luckly never snapped the ram though. Glad you enjoyed your experience ,and thanks for sharing!
