NH575E
Some of the hard line anchor straps were missing on my machine when I got it. A couple of lines were gouged up from unsecured movement. The rivet nuts to hold the straps were missing and the only place I found them was a China dealer on eBay. The holes in the boom are 11mm hex shape and the rivet nuts are 8mm with a 11mm hex base. It took several weeks to get them from China. At least they are easy to set without a tool. The hex base holds them so all it takes is an 8mm bolt and flat washer to secure them.
One of the crowd cylinder lines cracked on the outside. The line is listed at $550 and showing backorder. I Mig welded the crack and it sealed good enough for cylinder travel but as soon as I applied digging pressure it leaked again. The damage was less obvious after I cleaned it up so put a layer of brass over the whole section with a flux coated brazing rod. After brazing it didn’t leak and stayed dry even after digging and tugging on a stump some. I think the leak is fixed for now. BUT the rivet nut for the strap holding the line near the pivot popped out. I don’t think I put enough tightness on it when I set it so I have to replace that again tomorrow. I may loosen them all and tighten all the replaced rivet nuts in the boom a little batter if that one will tighten all the way down without breaking..
Every time I removed the line strap anchor bolts another one of the factory rivet nuts would break off and fall in the boom. I would have to chisel the top crimped part out and set a new one. If you have a New Holland you probably want to source some of these to have handy. I don’t know how common they would be with any other brand?
Edit: Found some of these on Amazon.
https://www.amazon.com/uxcell-Bronze-Carbon-Hexagonal-Nutserts/dp/B01MS63NZ7/ref=sr_1_3?crid=2ROKGQA8KMYJA&keywords=8mm+hex+rivet+nut&qid=1656384423&sprefix=8mm+hex+rivet+nut,aps,260&sr=8-3
![IMG_3490.JPG IMG_3490.JPG](https://www.heavyequipmentforums.com/data/attachments/246/246847-90e965ac3c25f3c38eb63287e376507c.jpg)
![IMG_3491.JPG IMG_3491.JPG](https://www.heavyequipmentforums.com/data/attachments/246/246848-10b941ae9f4cc2a5d760badb5f942da0.jpg)
