Someguy, you need to take a look at some really old scrapers and rethink that statement! In the 1920's scrapers started out as a simple scoop that dragged on the ground, pulled by horses.Then tractors. RG LeTourneau put the first "modern" scrapers on steel wheels, then rubber tires. Then upgraded them from mechanical means to electrically operated winches. First though, he had to develop the wire rope that made that possible.
He then was largely responsible for developing the modern rubber tire strong enough to handle the weight of earthmoving equipment. He developed the molds to make the tires, and swung a deal with Firestone where he sold the molds to them, after agreeing to buy the first million dollars worth they made! Then he thought, why not make the scraper move itself? So one guy could operate it.
Early rubber tired scrapers steered with steering clutches! Then RG decided to equip his with electric motors for almost all functions, including steering.
Everybody else tried hydraulics, or had to stick with a 2 axle tractor.
He got competition with Euclid, who made the first twin engine scraper in the late 40's, and later Cat in the late 40's after WW2.
Early hydraulics were slow compared to the cable units of the time, which is why they took awhile to come into further use, probably after hose technology allowed the use of the higher pressures to make the hydraulic sytems faster and more powerful.
Look under the back of an old DW21 sometime, look at how complicated the cable sytem is, and those huge return springs behind the ejector! And 4 rams to steer it with.
So as the late 50's early 60's come along, the 2 axle tractor fades from the scene except in the largest scrapers. Cat came out with the cushion hitch in about 1965, and started to take over the scraper market because of it.
Ask anybody who ever ran a stiff neck how much better the ride is with the cushion hitch! I'll bet Cat guards those patents like a hawk.
The early 60's also brought the 2nd major innovation, the automatic transmission, into widespread use, which no modern scraper is without.
Cat is largely responsible for the push-pull concept, which allowed scrapers to get away from using pushcats.
Case in point, a 627A had app. 400 Horsepower and a G has about 550, That's what a 651 had in 1965! We have electronic engine management, shift synchronisation, AC, sealed cabs with filtered air, boosted steering and very low effort controls, computers that can weigh each load onboard,
etc etc.....
About the only thing that has stayed the same is the basic layout of the machine itself, and the same can be said of dozers, loaders, blades, etc.
They still do the same basic job they did in the 1930's or earlier, so they still bear a resemblance to those early machines.
Until somebody makes a scraper ride on a cushion of air, or levitate on magnets, the basic layout won't change.
Maybe, can't change.
After all, a model T and a modern car still basically do the same thing, don't they? They are still a box on 4 wheels to carry people around...
Sorry about the long winded post....I'm done preachin' now!
Chime in, somebody...
alan
