Ford LT-9000 said:
Dwan how do you like your hook lift truck
I know where I can buy a 2006 F-550 4x4 with a Hiab multilift for 65000 dollars the truck only has 9000kms on it. From the pictures the mulitlift looks a little cheaply constructed. The truck is at a Hino dealership I have a feeling the truck maybe wasn't up to par and the guy traded it in on a new Hino. In the dealer's advertisement there was a 2006 Hino 3 ton with a hooklift on it now its sold.
The hino dealer wants 65,000 for the F-550 a little too pricey for my operation. There is no boxes with the truck so a person has to buy boxes the Hiab Mulitlift isn't a popular hoist.
Mine are Stellar Shuttle brand.
http://www.stellarindustries.com/ Got the one you see in the picture back in 1992 and had it custom made to fit the short truck (137" wb) F350 4x4 IDI. which also caries a plow in the winter. total cost for truck, plow, shuttle, and 1 flatbed was aprox $35,000. I liked it so well I got another one in 1995 set up the same waay except this one I mounted myseld because I did not care for the way the upfiter does there work. The 95 4x4 DI set up the same way minious the flatbed cost $42,000. Both have belt driven hydrolics. Both can load 5,000 from the ground up and both dump at over 53 degrees. I do feel the frames on the lift units are made of to thin of material and could be improved on. I would not be without one after having them. They are not cheap but have paid for themself every year sence I got them. If I did not need the plow I would have one mounted on a ISUZU NPR HD. I do overload the truck a lot more then I would like and my next one will probably be on a F550 unless Isuzu coms out with a 4x4 w/automatic.
rool off beds are easy to make. I have 2 flat beds, 1ea. 2 yd dump bed, 2ea. 2 yd sanders 1 ea. 500 gal hydroseeded and a real bed for CATV cable. Planed are a 2yd cement mixer, another dump bed for rock, a 8' box van, and a 185 cfm aircompreasure. I am also planing a trailer with a compatable shuttle system on it w/electric over hydrolic. As I work mostly alone and do my fabrecation between jobs these may take a while or may never get done but I keep pluging away.
I would not rull out the convitional roll off unit as there is one here in town that dumps just fine on a 1.5 ton cabover truck.
