materthegreater
Understood. Thanks!
I wonder how they are tightened? Don't look as though a wrench would fit nut or bolt.I'm not a truck mechanic. I really don't know anything about removing factory hardware like you are asking.
That said, a light hand with a torch on the bolt, or a grinder, would remove the huck bolt easily enough.
When I bought the C65 with Heil Dump body It had wooden strips installed as a padding between. I believe it wasn't routed for rivet heads, they just compressed into the wood over time.That makes sense, thanks
On the shifter, you are setting the maximum gear, it will drive like the auto in a pickup otherwise. Put it in 5 and forget about it. If you think it's not downshifting enough on hills you can shift it down to get more engine braking. If you pick too low of gear it most likely won't grab the gear or basically act like it's in neutral till the engine rpms would be in range then it might grab the gear. I don't think the 3000 has a deep reduction first but if it does it won't use 1st at all unless you put it in that gear.
On the pto does yours have a front engine pto?
This being VT, salt was pretty hard on the truck frame. The wood kept it wet much longer than it would have stayed wet otherwise. I bought the 1976 truck 29 years old from a summer only business in PA. Frame looked very good. 15 years later in VT, it didn't look near as good. I shy away from anything where two layers are sandwiched together. Where something does have to bolt to the frame, I use rustproof grease between layers.
