Garrett Ahlf
Finally got my parts in going Wednesday to put the shaft in and cross my fingers. I bought and extra bearing just in case. Should I get the bearing pressed on the shaft first or should I try and install shaft in existing bearing. Not sure if it will be pressed in and hard to pull out with existing bearing and shaft.Snap ring or shaft won't fall into the machine. Take a strong extendable magnet to pull the broken half of the shaft out. That bearing on the end of the shaft is pressed on. You might want to order the other snap ring and bearing (items 23 and 24) and have the assembly ready to just put in. Otherwise, you have to press the bearing off the old shaft and onto the new.
I don’t want to get back up there and get stuck in the middle of the job if I can’t pull the bearing and shaft out of the tractor. Thanks I’m advance for the advice
