6v92 & 8v92 interchangeability
Status
Not open for further replies.
Hallback
Aberdeen Wa.
Gyppo tower logger
So the old twin steer that I bought a few years ago has a 6v92 in it, It stuck a valve and broke the rocker stand in the head casting. I've got an 8v92 sitting here in the old westcoaster yarder. Would I be able to yank a head off that 8V92 and put it on the 6V?
Hallback
Aberdeen Wa.
Gyppo tower logger
The "6" and "8" refers to the number of cylinders and the "92" refers to the displacement of each cylinder. Same holds true for all the Detroits from the "53", "71", "92", "110" and "149"
And that is why I figured I could interchange the heads
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
I feel, (but don't really know) you'd be hard pressed to find a cylinder head compressor these days to install a 8V-92 cylinder head onto a 6V-92 cylinder block. Same thing to install a 6V head onto an 8V block with an appropriate cylinder head stretcher.
OzDozer
Perth, Western Australia.
Semi-Retired ..
Don't worry Hallback your in good hands-every expert salt water chevy man has answered your
prayers. I put return to sender on those wonderful items vetech flapped over.
Call Hagerman Salvage, but there should be a source for a replacement head in your area.
6V92's were real common.
There are heads all over in a wide range of price online.
Hallback
Aberdeen Wa.
Gyppo tower logger
Thanks TS!
Hope you have a Merry Christmas buddy and all is well over there.
Tyler d4c
Salix Pa
10 out of 10
9.5 out of 10 for originally
I may have laughed way to much at this
OzDozer
Semi-Retired ..
Don't forget so much WW2 equipment only got to its destination because they were powered by Jimmys - landing craft especially - and quite a bit of armor, too.
Mind you, the drivers and riders all ended up deaf, but at least they got there!
And they automatically covered themselves with oil to prevent corrosion. How brilliant an idea is that!
1693TA
Farmington IL
I actually like them. Maintained many over the years and still have a 3-53, 8V-71, 6V-92TA, and a 12V-71T at the shop. I use the International truck with the 92TA as my yard horse as the truck around it is no longer road worthy, but it runs well.
TS would think he'd died and went to a happier place if he ever came over here.....
Wouldn't even need to be too worried as I have a varied selection of DDA tooling around to take care of them also. He could even start right away:
Got a freshly rebuilt set of fuel injectors to install into this engine I just haven't made time for yet. Got a lopey idle for about 30 seconds upon cold start wanting to address.
Status
