By the looks of the pics, the sleeves don't look as if they have moved. The coolant in the sump may have come from removing the head.
I don't usually measure liner protusion when dismantling, but the fingernail test gives an indication that the block will be OK. You truely wont know how good it is, until it is stripped, cleaned & new liners are inserted.
Just thought I should clarify exactly where to look. It is between the outer flange of the liner & the block surface, this is the area where the fire ring of the head gasket seals.
It is important that there is not much difference between cylinders as this will affect the gaskets ability to seal.
Before cleaning, you will notice the sealing area of the fire rings, on both the liner flanges & cyl head, to be shiny & where there was any leakage (apart from the obvious) it will be dull or black.
