Sad state of understanding. All too easy to know after that many years.
One of the main share holders in Little Debbie lives in College Place. Trivia.Hey- I like me a Swiss Cake Roll now and then. You be nice to Debbie, she's gotten me through some pretty rough afternoons.
That’s sure gonna look good at my place when you’re done…..So went to the shop this morning and temp inside was 58, furnace running perfectly.
Was 6 here this morning.
Already had rods, pistons and rings installed on Friday, so this morning I installed all six
in block and camshaft, having the engine stand I really had to fart around to get a full
1.5 hours on install, cam 10 minutes. The reason I built the stand, too easy. Ready the
rod with bearings, check that rings are in position lube everything set in liner. Roll engine
to vertical install cap torque, roll back to horizontal. I really like being able to do a complete
assembly in my street clothes. Everything is clean no crap to wade in, engine goes together
like clock work, the way I remember years ago when I used a stand. Really after installing
the crank and cylinder kits in this block, I wouldn't do another with out it at my age.
Really any major shop or even a small one is stupid not to have one, the time saved
combined with the safety factor absolutely makes it a must. The best thing I've done for
myself in years.
The triangle pieces from the bottom of the roll always fall off. Its a design flaw that I'm forced to live with.The inside of those cranes covered in swiss cake roll crumbs and wrappers.
I have been running a Clean burn waste oil heater for 15 years. look simillar to TS black one. has 14,000 hrs on it. great unit with very little maintance.What brand is yours, and does it require outside air compressor? If you don't mind me asking.
I keep looking at them, if nothing else as a way to get rid of used oil. The ones I was around 15-20 years ago were fussy about burning and igniters, and needed outside air.
They certainly haven't gotten any cheaper. And only burning 1,000-1,500 gal of propane a year, its a long payback.
That is kinda scary. Safety and security depending on almost 50 year old equipment....Nuke has two 855s on Gensets, two on fire pumps. Nobody in house has a Clue how to read service manuals or has experience working on them. Cummins had to call a Tech in from PA to inspect head leaks and offer a repair plan. None of local Cummins techs knew what to look for as are not X series. Last full timer on Onan Gensets retired last year. All four are Small Cam. Also an 1160 sitting as a genset driver in a emergency service building, wanted Cummins to inspect for continued service, no gots nobody to do that!!!
All installed mid 1970s. Genset for security backup is a 16v92 siamese engine. That is also becoming a lead ballon.
I don't think the risk of the starts are a problem---but one that is-Old, liner O-rings leaking veryLet’s think about it; how many hot starts can you expect bearings to take before failure? Even with pre-lube there’s bound to be some damage.
Bars leak has been keeping the coolant upstairs in the c12 for many miles. If it blows up I'll put orings in it. Stupid idea cat had there with only 1 oring on the bottom of the sleeve.I don't think the risk of the starts are a problem---but one that is-Old, liner O-rings leaking very
slowly because of age, coolant in the basement. I get a kick out of people starting a wet sleave
engine that's been setting for X amount, and the seep starts. IMO.
