alan627b
Q1) Lines over the hitch include ejector, 2 bowl lift cylinders and apron. Some functions have a send and a return or bypass line. Some are for the cushion hitch cylinder. Air lines for the rear brakes, and rear throttle if equipped with a second engine. Electrical wiring to send the signal from the tractor transmission to the rear shift controller, and send and recieve from signals from various sensors. Remote rear start/shutdown on some scrapers.
6 of them are criss-crossed to allow the pivot movement of the hitch, or they 'd have to have an impossible amount of slack to allow turning. Might have a fuel send and return line, some may not have rear fuel tanks anymore.
2) Costs of used units depends greatly on the number of hours the unit has, the general condition of the unit, how it is equipped, whether or not it has push-pull equipment, as these units have additonal reinforcement in the structure for this application.
A unit used in rock or abrasive material will wear out much faster than a Midwest machine primarily used in clay, and will be worth less.
Cost also depends on the amount of new components included.
For example, a new set of tires for a 627 will run about $20,000 depending on what brand and quality you buy, radial or not, etc.
3) "New Paint" can mean "You should have seen waht an eyesore it was before we steamed all the crud off and took it to Earl Sheibs" and bondoe'd the sides of the bowl...don't laugh, I've seen it....paint and ArmorAll hide a lot.
Beware the Dupont overhaul.....
4) A 1974 627B could possibly have 100,000 frame hours on it. Don't believe an hour meter, they get replaced too. 5000 hours might mean "since the last time it was in the shop".
Buyer beware....
alan627b
Buyer beware....
alan627b
