shawnseveras
hi everyone so i have a client that has had this problem twice now. they bought the machine brand new and got some attachments for it and what not. the first time the model ran into trouble was when using the brush mower at 200+hours. the warning came up and because it was covered under warranty the machine was picked up by cat and looked at. they then told us that it was a common problem that the t770 has with the final drive motor or something to that effect. so they replaced both motors all filters and all the fluids. so they got it back and everything was running fine. then they got to 400+ hours and same thing happened. bobcat was called and the machine has shavings in it again. the solution im looking for here is can you replace all of the filters and do a full flush on it? if so would it be a double flush and filter replacement? they are just looking to get it back out there in the field. they said last time it took 6 months to get the skid steer back from the dealer and they dont want that to happen again. thoughts on what could have caused it to have this problem? because last i remember the filters are supposed to catch shavings right?
