Howey Matt
Cat 304CR (NAD00987)
I've got a boom cylinder that will extend but will not retract. In other words, boom goes up but won't come down. When I try to boom down, I hear noise from the relief valve, but the cylinder only moves about 1/4".
I don't have a way to test flow, but I have adequate pressure at the cylinder (~3,800 psi). There's also pressure at the other end of the cylinder, I assume, from the fluid trying to escape.
I swapped the lines at the cylinder. Now the machine will boom down but struggles to boom up. The boom does raise very slowly with the hoses swapped, but the relief valve is engaged the entire time.
The hydraulic shop just rebuilt the main control valve and bench-tested it, so I doubt it's the issue.
Could this be a malfunctioning relief valve? Any ideas would be greatly appreciated.
