husker farmer
A c13 (kcb) I'm considering is not holding OEM head gaskets. The head is a new OEM CAT and the mechanic suspects a block deck issue. The rest of the motor is in good shape, despite approximately 650k miles on the current build. The liners are in good position.
Is it advisable and is there a sealant to use on a new head gasket that would address the problem?
I'm not able to sink $ for a full rebuild, but was only going to do main and rod bearings along with the head gasket work.
This motor also has the single turbo conversion and tuned to about 510hp
Thoughts?
Thoughts?
