1693TA
That's when the railroad pinch point pry came out pivoting/fulcrumed on a 4X4 standing on a frame rail for the leverage while you forced upward bearing against casting flash, the "ledge" that slightly overhung the block surface, or a bolt or stud threaded into a mounting hole for some bracket. If that didn't work, you drove a very stiff blade scraper between the deck and head in several places to destroy the gasket and bond. Gawd, I remember the days.I don't want any of that. Hard to find a intake or exhaust port on a flathead.
Better to do things right, but all kinds of cowboys out there.....
Seen a guy in high school run the valves on a 302 Ford engine in a Maverick and used gasket shellac on the gaskets along with a brand new set of Mickey Thompson polished covers. No Polylocs and solid lifters so next time he wet to adjust, you guessed it, the original stamped rocker covers went back on as the nice aluminum ones had pieces broken out of them getting them removed from the engine.
